AMS-LYS, LYS-CDG-AMS: type of plane question
Good evening everyone,
I will be flying with EZY in the end of this year between AMS-STN and STN-LYS. Can someone tell me which type of plane they mostly use on those routes ? B733; B73G or A319 ?
And does someone know whether there are any rows which should be avoided due to bad window view or bad space ?
Many thanks in advance
EDIT: title changed since the routing changed
Re: EZY AMS-STD ; STD-LYS: type of plane question
Chris...STD?????????Avro wrote:Good evening everyone,
I will be flying with EZY in the end of this year between AMS-STD and STD-LYS. Can someone tell me which type of plane they mostly use on those routes ? B733; B73G or A319 ?
assume u mean STN as STD is in Venezuela
AMS-STN is operated by either 1 of the EZY a/c's so either the 733-73G and 319 8)
- B744skipper
I read somewhere that Easyjet used aircraft with roughly the same amount of seats, so they can interchange aircrafts when circumstances are asking for that (i.e: aircraft goes tech and another and flight gets operated by another type).Avro wrote:As for AMS-STN that's what I thought you cannot be sure of one specific aircraft type ....
But since STN is not a A319 base (or is it?) I guess you can expect to get an B733 or B73G, on my flights both sectors where listed as B733 but I got a B73G nonetheless on one sector (not that I did mind, they are really nice).
I got that one when flying from Luton to Amsterdam.
I can't give a specific answer to this question, but just make sure that you get to the airport early (be at the counter at least 2 hours before departure) so you get in the first boarding sequence (passenger 1 to 30). Then you can board the aircraft first, and find yourself a nice seat. Shouldn't be a problem since Easyjet has no assigned seats.And does someone know whether there are any rows which should be avoided due to bad window view or bad space ?
When I flew Easyjet I was really satisfied by the service they delivered to me, and I hope you will enjoy your experience with them as much as I did.
Thanks for your answers !!!
On a side note my plans have changed a little bit and I'm not sure know whether I'll fly EZY or with AF AMS-LYS-CDG-AMS. The flight with AF could suite me better the the timings but is more expensive (nearly the double) ...... So I don't know yet on which I'll be flying.
Another factor which is pushing me right now to opt for the AF flights is I would get to fly on F100, A318 and B735. All types of planes I still haven't flown on !!!
Anyway thanks again for your help Suppie and B744skipper.
Greetz
great can I also pick the jump seat then if I'm the firstsuppie wrote:Out of AMS we do free seating....so get yr ass on board asap and u can pick the best seat
Greetz
Re: EZY AMS-STN ; STN-LYS: type of plane question
Which day?Avro wrote:I will be flying with EZY in the end of this year between AMS-STN and STN-LYS. Can someone tell me which type of plane they mostly use on those routes ?
If I take e.g. 19 December, you will have:
AMS-STN: A319 (all three flights)
STN-LYS: A319 (all two flights. You can also choose Ryanair's B738 to Grenoble...)
- Sabena_690
Hi Chris,
The use of B737's with KL is very flexible: it all depends on the number of passengers/operational reasons/... It's impossible to predict which B737 will operate your flight.
It can either be a B733, B734 or B738, as KL uses all three types on their CDG shuttles. B739 is very unlikely.
Frederic
Frederic
- Sabena_690
You did not mention your flight numbers!According to OAG today (it can change!):
25 NOV AMS-LYS F100 KL
- KL1247: F70
- KL1249: F100
- KL1253: F100
- KL1259: F100
28 NOV LYS-CDG A318 AF
- AF7651: A318
- AF7653: F100
- AF7641: B737-500
- AF7643: A319
- AF7645: A318
- AF7649: F100
28 NOV CDG-AMS B737 KL
- KL1228: B737 passenger!
- KL1224: B737 passenger!
- KL1230: B737 passenger!
- KL1234: B737 passenger!
- KL1238: B737 passenger!
- KL1240: B737 passenger!
- KL1242: B737 passenger!
As Frederic said, KLM is very flexible.
- KL1247: F70
- KL1249: F100
- KL1253: F100
- KL1259: F100
- AF7651: A318
- AF7653: F100
- AF7641: B737-500
- AF7643: A319
- AF7645: A318
- AF7649: F100
