Kalitta 747-400 Dumping fuel
BigJets
Post by BigJets »
Kalitta 747-400 N740CK is dumping fuel at this moment. I heard multiple successive explosions as the aircraft past overhead.
BigJets
Re: Kalitta 747-400 Dumping fuel
Post by BigJets »
the aircraft is holding (fuel dumping) in front of the Belgian coast over the north sea
Treeper
Post by Treeper »
Heard it as well
BigJets wrote: 29 Mar 2019, 22:03 Kalitta 747-400 N740CK is dumping fuel at this moment. I heard multiple successive explosions as the aircraft past overhead.
And where is "overhead" ?
BigJets
Post by BigJets »
Meise, Merchtem, Opwijk as it was climbing out. The engine was shut down around Opwijk when the explosions stopped. It shows similarities to a birdstrike however the aircraft was already quite high, although not impossible for it to still be a birdstrike it might indicate that something else may be the cause.
BigJets wrote: 29 Mar 2019, 22:19 Meise, Merchtem, Opwijk as it was climbing out. The engine was shut down around Opwijk when the explosions stopped. It shows similarities to a birdstrike however the aircraft was already quite high, although not impossible for it to still be a birdstrike it might indicate that something else may be the cause.
Not higher than 7,000 feet, according to flightradar24
Treeper
Post by Treeper »
Seems to be returning to BRU.
BigJets
Post by BigJets »
Luchtzak, you're right, the Kalitta levelled at 7,000 feet. What I mean is that only about 10% of all birdstrikes are above 3,500 feet altitude and the explosions occurred at around 5 to 6,000 feet.
The aircraft is now on it's way to Brussels
LGG seems more likely.
Still flying at 7,000 feet but passed Brussels Airport
Treeper
Post by Treeper »
Still at 7000, way past LGG now. Perhaps CGN?
He is going to Leipzig....!?
Leipzig - Leipzig/Halle Airport
Frankfurt - Frankfurt–Hahn Airport
Ramstein - Ramstein Air Base
SR20
Post by SR20 »
luchtzak wrote: 29 Mar 2019, 23:05 Leipzig - Leipzig/Halle Airport
I bet on LEJ 😉
BigJets
Post by BigJets »
Break time for the crew, autopilot - engaged :)
Treeper
Post by Treeper »
Isn’t it common to declare emergency after a compressor stall? But to go and dump fuel over the North Sea, and then going 2000km or so to LEJ at 7000ft... seems a bit excessive when you’re passing all sorts of alternates, no?
Treeper wrote: 29 Mar 2019, 23:14 Isn’t it common to declare emergency after a compressor stall? But to go and dump fuel over the North Sea, and then going 2000km or so to LEJ at 7000ft... seems a bit excessive when you’re passing all sorts of alternates, no?
3 engines still running, and perhaps maintenance bay in Leipzig ?
luchtzak wrote: 29 Mar 2019, 23:41
I think I just easy for the Cargo to be overloaded to another plane going to the USA.
Safely landed at Leipzig Airport.
