Re: Abnormalities in BRU-ANR-CRL-LGG-OST in 2018
sn26567 wrote: 27 Feb 2018, 09:46
convair wrote: 27 Feb 2018, 01:28
Btw, who got the BRU Punctuality Award yesterday?
Iberia
.. on medium-haul, and ANA All Nippon Airways on long-haul.
Read more: https://www.aviation24.be/airports/bruss ... on-awards/
Looks like CRL is closed for the moment....
Not really abnormal in winter though.
EBBR closed for arrivals.
ATIS Bravo 1608.
Foxtrot 1626 EBBR still closed to ARR.
Departures on RWY 07R. I suppose the Winter team is working at clearing RWY07L.
Looks like AY and a couple of SN went to EBLG.
So from 1608 till 1626 the ATIS went from Bravo to Foxtrot? A speed record, perhaps!
jan_olieslagers wrote: 02 Mar 2018, 17:41 So from 1608 till 1626 the ATIS went from Bravo to Foxtrot? A speed record, perhaps!
Looks like indeed.
1641 ATIS India !!
Several diversions :
SN LIS >> OST
SQ Cargo >> AMS
Hop LYS >> LIL
LH MUC >> DUS
SK ARN >> DUS
OS VIE still in the hold at Flora
FR MXP same.
BRU ATIS DEP:
EBBR DEP ATIS Y 1650Z
EBBR NAT,
DEP RWY07R
RSCD RWY07R WET SN BA111 BATIME1638 ARR CLOSED TL FL055 TWYS AND APN SLIPPERY
090/6KT MNM3 MAX11 VIS 2400M FBLSN FEW300FT BKN700FT
TMS3 DPMS5 QNH 995HPA
BECMG VIS3500M SCT700FT BKN1300FT
CONFIRM DEP Y
BRU ATIS ARR:
EBBR ARR ATIS J 1650Z
EBBR NAT,
ARR CLOSED
DEP RWY07R TL FL055 TWYS AND APN SLIPPERY. MOD ICE REP BTN GND AND 3 THOUSAND FT
CONFIRM ARR J
JVSpotter
Post by JVSpotter »
Last update: 18:29
Code: Select all
Diversions:
AEA1173 E195 EC-LFZ to EIN
SQC9751 B744 9V-SFK to AMS
BTI6C3  DH8D YL-BAY to AMS
AZA88P  A321 I-BIXP to AMS
MAC111  A320 CN-NMM to AMS
FIN8MZ  E190 OH-LKO to LGG
BEL98M  A320 OO-SNA to LGG
BEL21T  E145 G-CKAF to LGG
AEE6TH  A320 SX-DVQ to DUS
DLH1HH  E195 I-ADJU to DUS
SAS1589 B736 LN-RCT to DUS
SAS4745 B737 LN-RBB to DUS
AUA353D A319 OE-LBW to DUS
RAM830F B737 CN-ROD to CDG
TAP618  A320 CS-TNG to CDG
DLH9JA  E195 D-AEMB back to MUC
BEL61B  A320 OO-TCQ to OST
FIN38U  E190 OH-LKH to HAM
IBE32BT A329 EC-IEF to ORY
HOP316M E145 F-GUBC to LIL
RYR59NK B738 EI-FTE to CRL
How come BRU seems to be the only one impacted ?
Its snowing everywhere
SR20
Post by SR20 »
Acid-drop wrote: 02 Mar 2018, 18:11 How come BRU seems to be the only one impacted ?
It looks like they just cleared RWY19 and opened it for landing (braking action medium)
I guess visibility/ceiling was not sufficient to continue landings on 07L and they had to revert to a more suitable runway (ILS equipped) wich probably was not treated on time. But that's a guess ;)
I'd figure that when your airport has 1 flight per hour your winter team has access to the runway for snow sweeping.
CRL arrivals : 1549 - 1620 - 1714 - 1740
Suppose BRU had to focus on maintaining one RWY active (it remained open for DEP).
Also looks like this is wet snow, falling on ground that is below freezing temp. No fun.
Probably the ILS critical areas would need to be swept as well though arrivals should remain on 07's for a while hence no ILS.
LUX is also closed. It's not in Belgium, but it's managed by a Belgian ;)
SR20
Post by SR20 »
Homo Aeroportus wrote: 02 Mar 2018, 18:23
Funny, in LGG it's dry snow !
EBLG ATIS G 1720Z
EBLG INFO,
EXP VECT FOR ILS APP ARR RWY04R DEP RWY04R
RSCD RWY04R DRY SN BA221 TL FL050 RNP 04R. NO RIGHT TURN ON TWY A FM TWY S3. . ADZ ON GND FREQ IF UNABLE DEP S2. TWY SLIPPERY
120/9KT VIS 900M RVR RWY04R 1900M ABV2000M 1900M MODSN SCT300FT BKN700FT
TMS3 DPMS4 QNH 995HPA
TEMPO VIS0800M MOD SN BKN300FT
CONFIRM ATIS G
I drove my winter tyres equipped car over a concrete road and it was slippery as hell, I totally understand it at Brussels Airport!
Hence I wrote a small article: Snowfall on frozen tarmac disrupts air traffic at Brussels Airport
CRJ 900
Post by CRJ 900 »
Stuck in BCN. late evening flight to BRU cancelled. No idea on solution yet: SN will look for extra BCN flight tomorrow if they find a plane. Flight was nearly full so a lot of people to take care of. Keep you posted.
Rgds
CRJ 900
b.lufthansa
Post by b.lufthansa »
b.lufthansa
b.lufthansa
Update Brussels Airport 20:40: At the moment, 130 flights are cancelled. Check your flight info online before coming to the airport. We’re installing beds and distributing food and water. Winter teams are working hard to clear a second runway.
b.lufthansa wrote: 02 Mar 2018, 20:36 ????
That is the daily Delta flight DL043 code-shared with AF.
