pitrixplanespotting wrote: 05 Aug 2017, 21:11 Ex SN OO-DWA will be used as a tanker!
Source: https://www.planespotters.net/airframe/ ... te/xypys1K
Website 'airline': http://aerofliteinc.com/
Thanks for the tip!
https://www.aviation24.be/airlines/aero-fl ... er-oo-dwa/
luchtzak wrote: 06 Aug 2017, 11:46
Thanks for the tip!
VRT nieuws: http://deredactie.be/cm/vrtnieuws/buitenland/1.3040548
Matthias
Post by Matthias »
Does anybody knows what happened to G-ECOK? Looks like he hasn't been flying around for some time. It flew to EXT on 01/08. Is it for paint in normal cs? Also, G-RJXI hasn't been flying around for some time as well. Also for paint? And it also seems that a lot of ERJ-flights just don't fly.
mad_fab
Post by mad_fab »
Someone on reddit is apparently working on scrapping old SN birds..
http://imgur.com/oCVRUCR
Those are OO-DWB and DWL.
K has been scrapped.
SWISS is studying the new A321LR, as the aircraft can reach new markets for the carrier, including the US East coast.
This should be a Lufthansa Group project, not limited to SWISS. I'm sure SN could also make good use of such aircraft.
sn26567 wrote: 23 Aug 2017, 16:10 SWISS is studying the new A321LR, as the aircraft can reach new markets for the carrier, including the US East coast.
And now I read that the CEO of SWISS would use them on African route! In competition with SN????
http://atwonline.com/airframes/ceo-swis ... ica-routes
OO-ITR
Post by OO-ITR »
sn26567 wrote: 23 Aug 2017, 19:21
not sure about that. nowhere in the article it is mentioned that the aircraft will be used to open destinations where SN is already flying.
Remember that North Africa is also Africa... 8-)
crew1990
Post by crew1990 »
OO-ITR wrote: 23 Aug 2017, 21:09
Yes but there is no need of a A321LR to fly Zurich-north america, a normal A321 can make it, and normal A321, Swiss already have some.
crew1990
Post by crew1990 »
I m still convince that this is not the right aircraft to fly for Africa, because with the actual network even the A330 are almost full everyday, if not in cabin, it s full in the belly. The A321LR doesn't have such cargo capacity. The only point I would see the A321LR would be on long haul leisure destination as there would be almost no cargo and there Is no proper business class needed.
However I still think that a couple of standard A321 would be nice for the European sector and Tel Aviv
Ansett wrote: 23 Aug 2017, 22:34 Wasn't this suggested by luchtzak members already quite some time ago ? A320 family aircraft from BRU to Africa and as well as a NYC late evening flight ? I seem to remember the idea was considered "unworkable", also by SN management, but when Swiss CEO considers it, it gets serious attention.
Indeed, Flanker where are you? CEO at Swiss?
Airbus330lover
Post by Airbus330lover »
:lol:
I did on some African destinations it can work for example Luanda there is not much belly cargo and a A330 is to big and so you can start an non stop flight..
Also Dakar with a second flight could work.
Dakar is a short flight so maybe with two flights with a A321LR you can also take enough belly cargo but about this I'm not sure.
Treeper
Post by Treeper »
lumumba wrote: 24 Aug 2017, 10:27
Dakar is a short flight so maybe with two flights of a A321LR you can also take enough belly cargo but about this I'm not sure.
If I remember correctly there can be only 1 flight between Senegal and Belgium, due to bilateral agreement.
Correct me if I'm wrong
Treeper wrote: 24 Aug 2017, 11:13
I don't now but for sure Senegal is very liberal in that matter from France you have a lot of different companies flying there even charter.
Anyway it's negotiable....
DeltaWiskey
Post by DeltaWiskey »
Various departments within Brussels Airlines are also studying the A321LR.
The A321LR is a much different aircraft from the A319LR (ceo), which a member of this forum advocated for sub-sahara operations in the past.
JOVAN
Post by JOVAN »
Poiu wrote: 23 Aug 2017, 23:07
Flanker Always had good strategic ideas.
I think he quit the Forum ??
Pity so many members here tought they new better.
Discussions now are less interesting.
Sabena320
Post by Sabena320 »
I think the chances of SN deploying A321's to Africa, except for maybe a single route, are slim. These aircraft simply don't have enough payload capacity for luggage and cargo load together. If they add A321's to their fleet it would probably be for high loadfactor routes as to the Canary Islands, BCN and other tourist destinations.
Sabena320 wrote: 24 Aug 2017, 15:38 I think the chances of SN deploying A321's to Africa, except for maybe a single route, are slim. These aircraft simply don't have enough payload capacity for luggage and cargo load together. If they add A321's to their fleet it would probably be for high loadfactor routes as to the Canary Islands, BCN and other tourist destinations.
But this discussion is specific to the A321LR ...
