TUI fly Belgium in 2017
Re: TUI fly Belgium in 2017
Tomorrow Vamos Air EC-KSM Boeing 747 comes to the rescue.
https://www.aviation24.be/airlines/tui-fly ... reamliner/
The guy from Claim it, knowing that the press would be there, rushed to the hotel to make a statement on tv: his usual "passengers are entitled to an indemnity of 600 €...". This is how VTM news quotes him: ...“Na drie uur wachten bij de gate werd er eindelijk medegedeeld dat het onderdeel dat vervangen dient te worden niet in België ligt en dat de vertraging daardoor zeker 72 uur zou bedragen” zegt Ralph Pais van Claim it, de organisatie die opkomt voor de rechten van de passagiers. Hij benadrukt nog dat iedere passagier recht heeft op een schadevergoeding van 600 euro. “Het is stuitend om te zien dat telkens passagiers de dupe worden van mankementen aan Boeings paradepaardje, de Dreamliner”, besluit Pais...
https://nieuws.vtm.be/binnenland/deur-v ... s-gestrand
Not that fast, mr. Pais. On 15th June 2016, the Journal of the European Union has published C/2016/3502 = the Commission Notice "Interpretative Guidelines on Regulation (EC) No 261/2004 of the European Parliament and of the Council establishing common rules on compensation and assistance to passengers in the event of denied boarding and of cancellation or long delay of flights..."This Notice makes clear when a technical failure can be seen as extraordinary circumstance. And me thinks that the failure of a door seal is acceptable as extraordinary circumstance, specially on a rather new aircraft like TUI's 787:
5.1.: Principle ... ... Finally, in case of technical problems extraordinary circumstances must relate to an event which meets two cumulative conditions: first, it is not inherent in the normal exercise of the activity of the air carrier concerned; second, it is beyond the actual control of that carrier on account of its nature or origin...
5.2. goes into details about "Technical defects". And though it's no general rule, me thinks again that a door seal failure applies as extraordinary circumstance: ... ...For instance, a breakdown, such as that at issue which was caused by the premature malfunction of certain components of an aircraft may constitute an unexpected event...
Relevant EU Notice (change of language is possible):
http://eur-lex.europa.eu/legal-content/ ... 15%2801%29
DeltaWiskey
Post by DeltaWiskey »
I don't really see that how a technical-extraordinary-circumstance-excuse can be used. Opening and closing aircraft doors is a normal part of operating an airline, maybe something/someone hit that door seal that rendered it unserviceable?
I think that paragraph is mainly used for technical faults resulting from bird/lightning strike, etc
The whole EC261 regulation is pretty ridiculous, it doesn't matter if an aircraft is delayed 3 hours or 3 days, the compensation is exactly the same...
Yuqu12
Post by Yuqu12 »
The reasoning behind it may not be the most logical onz, but it is already good that there is some form of compensation for the passengers
Replacement aircraft: TUI (NL) 787-8 reg PH-TFM. Scheduled departure out of BRU: today 15h00.
https://www.flightradar24.com/data/aircraft/ph-tfm
T4J
Post by T4J »
The deffective part is not a seal, but a bearing on the door pull in mechanism. This issue prevents the cargo door from closing and obviously leads to flight cancellation.
Yuqu12 wrote: 01 Jul 2017, 10:00 The reasoning behind it may not be the most logical onz, but it is already good that there is some form of compensation for the passengers
Passengers who have booked a package (hotel & stay) may expect a % pro rata compensation for the lost holiday-days, as stated by Belgian travel legislation. TUI usually confirms this within days after the event.
For passengers who have booked a ticket only, there is no such indemnity when the airline regards it as an unforeseen technical failure = extraordinary circumstance = no indemnity. I would advise them to contact the airline's commercial department.
T4J wrote: 01 Jul 2017, 10:47 The deffective part is not a seal, but a bearing on the door pull in mechanism. This issue prevents the cargo door from closing and obviously leads to flight cancellation.
Thanks for the explanation T4J !
Passenger wrote: 01 Jul 2017, 10:38 Replacement aircraft: TUI (NL) 787-8 reg PH-TFM. Scheduled departure out of BRU: today 15h00.
PH-TFM is just airborne for AMS-BRU:
https://www.flightradar24.com/data/airc ... fm#ded8e09
luchtzak wrote: 30 Jun 2017, 21:01 Tomorrow Vamos Air EC-KSM Boeing 747 comes to the rescue.
And on his way to Punta Cana meanwhile - flight TB-601:
https://www.flightradar24.com/data/airc ... sm#ded5faf
The Dreamliner OO-JDL is flying again:
https://www.flightradar24.com/data/aircraft/oojdl
G-POWD, a Titan 767-300ER, did TB-7113/TB-7114 Brussels-Tenerife-Brussels:
https://www.flightradar24.com/reg/g-powd
Airline Route published the schedule of the future Antwerp-Innsbruck flights of next winter
TUIfly Belgium in recent OAG Schedules Analyser update has filed operational schedule for Antwerp – Innsbruck route, currently scheduled for winter 2017/18 season. The airline’s preliminary schedule filing shows the airline proposing 2 weekly operation from 22DEC17, on board Embraer E190 aircraft.
Code: Select all
TB5417 ANR0630 – 0745INN E90 5
TB1417 ANR0800 – 0915INN E90 1
TB5418 INN0845 – 1005ANR E90 5
TB1418 INN1015 – 1135ANR E90 1
Strange: G-OBYF, a Manchester based TUI (UK) 767-300ER, just landed in BRU Brussels, coming from MAN Manchester as 6B-9007 / BLX-9007.
Next flight, according to Flightradar, is BRU-HEL Brussels-Helsinki BLX-9008. And after that: HEL-MAN (BLX-9009).
https://www.flightradar24.com/data/airc ... yf#df98976
https://www.flightradar24.com/data/aircraft/g-obyf
wapo84
Post by wapo84 »
To HG40
OO-TUP / EC-JBL is arrived from PMI today,still the Spanish reg but with new colors,spotted on Planespotters @ BRU FB group
Edit : Just seen here : http://www.mobilit.fgov.be:7081/bcaa/ai ... search.jsf
OO-TUP is registrated since today by TUI,so need to go to the paintshop...
TLspotting wrote: 07 Jul 2017, 21:14 OO-TUP / EC-JBL is arrived from PMI today
TUI fly Belgium took delivery of one B737-800, serial 33974.
sn26567 wrote: 10 Jul 2017, 18:16 TUI fly Belgium took delivery of one B737-800, serial 33974.
FPG Amentum (Ireland) delivered two B737-800s, serials 33974 and 35647, to TUI Airlines Belgium. Serial 35647 transitioned from Norwegian and is managed by FPG Amentum on behalf of a JOL owner, while serial 33974 transitioned from Air Europa (Spain) and is owned by FPG Amentum’s investor customer Global Aircraft Fund I.
According to Huffington Post Maghreb, TUI fly will launch a route between Marrakesh and Turin every Saturday from 4 November.
Elke Pattyn and André Berger (and little Julie) have a new family member: Charlie.
https://www.instagram.com/p/BYWBER0lSKN/
