Brussels Airlines rewards scheme (Miles and More / Loop)
Frederic_K
Post by Frederic_K »
Hiya
I'm curious to discover what you think about M&M vs Loop. When to choose what?
In my mind: only if you are sure to take 30 flights or really long distances in 1 year M&M is a good choice, otherwise i'd go for loop.
Shame the M&M logic requires you to do it all in 1 year.
Re: Brussels Airlines rewards scheme
I personally have selected M&M because since years I get additional miles that never expire for using my Amex card. I don't know if that possibility exists with Loop.
So if I understood well you have to choose between the two?
That's why my Loop doesn't work....
You don't have to choose once for all. You can choose at each trip.
sn26567 wrote: 01 Jul 2017, 09:59 You don't have to choose once for all. You can choose at each trip.
Ha ok thx...
Oiseau du Ciel
Post by Oiseau du Ciel »
I'm using Loop, I started in januari '16 but I don't fligh that often so I chose Loop since they last one year, not regarding if you fligh once, twice or ten times a year. Some actions give you extra loops. Quite happy with it.
Frederic_K
yes but does M&M make sense if you're under 30 flights per year?
So my guess would be you have to make a choice at the start of the year and stick to it - if you want some benefit?
cathay belgium
Re: Brussels Airlines rewards scheme (Miles and More / Loop)
Post by cathay belgium »
Depends if you have a creditcard connected with your M&M..
Don't fly normally above 30 flights a year ( with S* ) but with the creditcardmiles I do get some
miles enough for a bit cheaper LH meilenschnappchen every 2 years or so ;)
But I must admit with the 'new' rules I don't care about both loops or M&M , I prefer errorfares :mrgreen:
CxB
New types flown 2022.. A339
