SN 203 Brussels - Dakar delayed
airbuske
Post by airbuske »
09/04 11:35 Dakar delayed SN 1203 17:00
via Banjul
Big delay ( 5u25min)
Does someone knows why?
I suppose technical problems?
Greetings
Airbuske :)
blackhawk
Post by blackhawk »
Today there are also a lot of cancelled flights. yesterday too.
Are there problems with VLM because it seems that all / a lot of their flights to Londen City (today as well yesterday) are cancelled.
AN124
Post by AN124 »
No problems I think,
More something to do with Easter.
Best Regards,
Yvo
meerkat
Post by meerkat »
Today is Good Friday in the UK - a bank holiday & part of the Easter break, so few business open today. Big football match too Arsenal - Liverpool kick off 12.30 BST
Meerkat
vflies
Post by vflies »
According to Sky News, a staggering 2.1 MILLION Brits will travel abroad TODAY!
1.5 million thru London's five airports!
Wow. Some numbers make you dizzy. I'm just glad I'm not travelling today! ;-)
VFlies
That still doesn't explain why SN 203 is late today. And why it has a double code: SN 203 and SN 1203...
BMO
Post by BMO »
sn26567 wrote:That still doesn't explain why SN 203 is late today. And why it has a double code: SN 203 and SN 1203...
I don't know the politic of SN now, perhaps they've had a delay wit an earlier destination with the same plaine? 8O
JM
more info
Post by JM »
apparently a tech problem was reported yesterday evening, but SN technics didn't have enough staff available to repair this problem immediately. So instead of searching staff, they prosponed the repairment till today, and that's the reason for the delay...
So now the reason why it became SN1203 : the order in which they fly changed : they serve dakar and banjul the other way round then originally planned ( with SN203 ). When they do this, SN has to open a new flightnumber and rebook everyone on that new flight ( or that's what i'm told anyway, same happened a while back )
Today they also boarded by bus, to gain time, and seen RWY02 and 07R are in use and our reliable (hrrrm) SFM was at hangar 41... you get the point don't you ? :-)
greetz JM
Glider
Post by Glider »
... and suddenly she was there, at 07L. She took off indeed around 17 o'clock.
JM
Post by JM »
are you sure it was 07 L ??? I thought he was at hangar 41 ...
JM wrote:I thought he was at hangar 41 ...
That's not possible: all three A333s landed safely from Africa this morning...
Glider
Post by Glider »
Oops, yes, you're right JM. Was a bit confused. Of course, it was 07R :oops:
