Hiya
I'm curious to discover what you think about M&M vs Loop. When to choose what?
In my mind: only if you are sure to take 30 flights or really long distances in 1 year M&M is a good choice, otherwise i'd go for loop.
Shame the M&M logic requires you to do it all in 1 year.
Brussels Airlines rewards scheme (Miles and More / Loop)
Re: Brussels Airlines rewards scheme
I personally have selected M&M because since years I get additional miles that never expire for using my Amex card. I don't know if that possibility exists with Loop.
So if I understood well you have to choose between the two?
That's why my Loop doesn't work....
You don't have to choose once for all. You can choose at each trip.
I'm using Loop, I started in januari '16 but I don't fligh that often so I chose Loop since they last one year, not regarding if you fligh once, twice or ten times a year. Some actions give you extra loops. Quite happy with it.
- cathay belgium
Re: Brussels Airlines rewards scheme (Miles and More / Loop)
Depends if you have a creditcard connected with your M&M..
Don't fly normally above 30 flights a year ( with S* ) but with the creditcardmiles I do get some
miles enough for a bit cheaper LH meilenschnappchen every 2 years or so
But I must admit with the 'new' rules I don't care about both loops or M&M , I prefer errorfares
CxB
CxB
New types flown 2022.. A339
