ATC: mode C, mode S,ADS-B out,new F-pln 2012 regulation
Anyone from the tower to explain the new rules to fill-in the new flight plan 2012?
Transponder mode C, mode S. alternate 1,2,, etc... how can one know, what equipment is installed on the A/C?
and how to write the new form correctly?
Re: ATC: mode C, mode S,ADS-B out,new F-pln 2012 regulation
I was not aware of new ruling - any pointers, please?
But as for "how can one know, what equipment is installed on the A/C?", the POH is the obvious place to start looking. On a rental plane, knowing what equipment is operational might be harder...
Or in this document as of p15: affected fields
I've only had the time to read the documents diagonally, but I have the impression that most changes are mere cosmetic except for the field that regards the equipment. Has anyone already gone through the necessary documentation or found a good summary?
Got this in my mailbox a week or three ago. Don't know if it gives you more structured info, am a total nublet when it comes to FPL stuff, but thought it might help. If not, sorry for loss of bandwith
- Attachments
- Filing of ICAO NEW Flight Plan Format 2012(26-10-12).ppt.ppt
- (1.45 MiB) Downloaded 181 times
No waste at all, very interesting! Many thanks!
On the contrary! That is an extremely useful presentation. Provided that it is indeed correct, it should be dissipated across FTO's, RF's and flying clubs as soon as practicable! Thanks!Squelsh wrote:Got this in my mailbox a week or three ago. Don't know if it gives you more structured info, am a total nublet when it comes to FPL stuff, but thought it might help. If not, sorry for loss of bandwith
You're very welcome, glad it got to good use. Even after going through those slides a second time I still don't get it anyways
Well, that's perfectly normal if you don't have an aviation background offcourse. Even people who are almost at the end of their ATPL training still need to absorb all possible abbreviations used in aviation
It's like learning chinese!
Thanks for the info's, the most difficult being the 'J" stuff,CPDLC VDL mode A, mode 2,Alternate mode2,....
Something that worth metionning here, it the coming postponement of the ADSB-OUT mandate by EASA.
This is yet to be published in the regulations, but seems a firm decision.
Source : http://www.ainonline.com/aviation-news/ ... nt-mandate
Also, the rumour says that EASA will postpone CPDLC implementation date by a few years. Has anyone read anything on this ?
